[mapguide-trac] #1588: Update license checking code
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 21 13:06:50 EST 2011
   Reporter:  brucedechant  |       Owner:  brucedechant
       Type:  enhancement   |      Status:  new
   Priority:  low           |   Milestone:  2.3
  Component:  General       |     Version:  2.2.0
   Severity:  trivial       |    Keywords:
External_id:                |
Changes (by brucedechant):
  * owner:  => brucedechant
Old description:
> Change the exisitng license checking code to allow the CheckLicense() API
> to be overriden for any operation or to use the parent method.
> Note: The LicenseManager method called by the CheckLicense() API doesn't
> actually do anything. If you want to implement your own licensing you
> will need to add your own license checking code there.
New description:
 Change the exisitng license checking code to allow the !CheckLicense() API
 Note: The !LicenseManager method called by the !CheckLicense() API doesn't
 actually do anything. If you want to implement your own licensing you will
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1588#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
