[mapguide-trac] #1592: the plot preview is not generated correctly when user rotate the clip box
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 30 03:17:46 EST 2011
   Reporter:  hubu         |       Owner:  hubu
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:  quick plot
External_id:  1380255      |
 the problem happens only when the web extension is configured with
 IIS+.Net  or Apache+Java
 Steps:
 1. Open a BWL on Browser
 2. click 'Quick plot', so the quick plot form appears in the task pane
 3. in the Quick plot form, tick 'Advanced Options', so the clip box
 appears in the map, showing the print area and allowing user to adjust the
 view
 4. in the map, rotate the clip box by 90 degrees clockwise
 5. click 'Generate' button and check the preview
 result:
 the preview image is not correct, refer to attachment 'quick plot.png'
 expectation:
 the preview is changed as user rotates the clip box
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1592>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
