[mapguide-trac] #1592: the plot preview is not generated correctly when user rotate the clip box
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 30 03:24:44 EST 2011
   Reporter:  hubu         |       Owner:  hubu
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:  quick plot
External_id:  1380255      |
Comment(by hubu):
 The reason of this issue is there are some errors in the regular
 expression in Aspx/Jsp.
 When the user rotate the clip box by 90 degrees, the value of the rotation
 in Aspx/Jsp is -90. However, the regular expression can't handle the
 negative numbers.
 I attached the patch for this ticket.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1592#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
