[mapguide-trac] #1593: Mapguide OEM install failing make check tests
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 30 17:09:33 EST 2011
   Reporter:  dbx2011       |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.2
  Component:  Build System  |     Version:  2.2.0
   Severity:  critical      |    Keywords:
External_id:                |
 Hi. After a considerable amount of time spent fiddling I managed to get a
 sucessfull build of Mapguide on Debian Lenny.
 However a 'make check' is failing, the full output is attached.
 !!!FAILURES!!!
 Test Results:
 Run:  257   Failures: 4   Errors: 0
 1) test: TestMdfModel::TestStart (F) line: 90 TestMdfModel.cpp
 forced failure
 - The specified file was not found: ../UnitTestFiles/MdfTestMap.mdf
 2) test: TestMdfModel::TestCase_Serialization (F) line: 415
 TestMdfModel.cpp
 forced failure
 - Resource was not found:
 Library://UnitTests/MdfModel/MdfTestMap.MapDefinition
 3) test: TestRenderingService::TestStart (F) line: 333
 TestRenderingService.cpp
 forced failure
 ../UnitTestFiles/UT_SheboyganWithWatermark.mdf
 4) test: TestRenderingService::TestCase_RenderMapWithWatermark (F) line:
 562 TestRenderingService.cpp
 forced failure
 Library://UnitTests/Maps/SheboyganWithWatermark.MapDefinition
 ./unittest.sh: line 5: 32278 Aborted                 ./mgserver test
 FAIL: unittest.sh
 1 of 1 tests failed
 Please report to http://mapguide.osgeo.org
 I also get some odd permission issue when running a 'make install', also
 attached.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1593>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
