[mapguide-trac] #1593: Mapguide OEM install failing make check tests
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 30 21:59:08 EST 2011
   Reporter:  dbx2011       |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  2.2
  Component:  Build System  |     Version:  2.2.0
   Severity:  critical      |    Keywords:
External_id:                |
Comment(by dbx2011):
 the permissions problem with the 'make install' was due to cp trying to
 copy the ACL from the build location to /usr/local . Resolved the issue by
 mounting /usr with ACL
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1593#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
