[mapguide-trac] #1594: Layer with EPSG:3398 CS not visible after publishing as WMS
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 30 21:44:22 EST 2011
   Reporter:  liuar          |       Owner:  liuar
       Type:  defect         |      Status:  new
   Priority:  medium         |   Milestone:
  Component:  WMS Interface  |     Version:  2.2.0
   Severity:  minor          |    Keywords:
External_id:  1383844        |
 A spatial query should be applied on layer while the required boundingbox
 is larger than pre-defined publishing area.[[BR]]
 The required boundingbox is defined under MapCS which should be
 transformed to LayerCS before appling the spatial query.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1594>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
