[mapguide-trac] #1729: Bundle WebStudio pattern images as embedded resources
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 28 07:16:27 EDT 2011
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-3.5
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 The Maestro.Editors assembly currently assumes that a WebStudio folder
 exists in the directory this assembly resides in which contains all the
 line pattern images that are referenced by the geometry style editors.
 This requirement hampers the ability to use Maestro.Editors outside of
 Maestro.
 These images should be bundled into the assembly itself as embedded
 resources.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1729>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
