[mapguide-trac] #1729: Bundle WebStudio pattern images as embedded resources
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 28 07:22:12 EDT 2011
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-3.5
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by jng:
Old description:
> The Maestro.Editors assembly currently assumes that a WebStudio folder
> exists in the directory this assembly resides in which contains all the
> line pattern images that are referenced by the geometry style editors.
> This requirement hampers the ability to use Maestro.Editors outside of
> Maestro.
> These images should be bundled into the assembly itself as embedded
> resources.
New description:
 Maestro. The assembly should be as self-contained as possible.
 One way to improve this is to have these images bundled into the assembly
 itself as embedded resources. This may inflate the size of the
 Maestro.Editors assembly, but would greatly improve the portability.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1729#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
