[mapguide-trac] #1698: Map Editor: Calculated combined extents button returns extents in lat/long regardless of coordinate system assigned
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 20 03:55:28 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> I got an unconfirmed report that the button to calculate the combined
> extent from all layers returns extents in lat/long even though the
> coordinate system assigned was not.
> Verify if this is the case.
New description:
 Update: I have confirmed that the calculate combined extents button is
 indeed not functioning under certain circumstances, especially if one or
 more layers are not in the Map's coordinate system.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1698#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
