[mapguide-trac] #1708: Edit schema button can sometimes show wrong schema
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 30 08:05:02 EDT 2011
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:  2.1.0
   Severity:  minor    |    Keywords:
External_id:           |
 In Maestro 3.1, create a new ODBC feature source. Then select a name via
 DNS and click "edit schema". Then select a different DSN and click "edit
 schema" and you will see the schema for the 1st DSN selected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1708>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
