[mapguide-trac] #1477: ODBC dataconnection (MS Access) problem
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 30 08:39:25 EDT 2011
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by andrewd):
 Unfortunately not - though the error's a bit more explicit now. It would
 seem that the problem is with how it's handling (or failing to handle) a
 specific field type ("single"). Here's the error I get when I test the
 connection (this is the same error for multiple DNS's:
 FDO Connection Status:
         The remote server returned an error: (559) MgFdoException.:
 An exception occurred in FDO component.
 Error reading Feature Schemas from XML; class 'www-dot-w3-dot-
 org/2001/XMLSchema:single' for object property 'Fdo:Section_Data.Station'
 not found.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1477#comment:13>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
