[Mapguide-trac] [mapguide-trac] #2085: Maestro - Theme Improvements - Loss of transparency
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 27 05:07:56 PDT 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-5.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 The theme improvements based on the initial (existing) thematic style do
 not preserve transparency.
 Create a style on an area layer with transparency
 Launch the thematic builder and select to use style from first rule
 Build style and apply
 Expected Result: transparency is preserved along with colour etc
 Actual Result: transparency settings are lost
 Current workaround is to reapply transparency on a per theme basis.
 In addition the "Change Base Style" button does not allow me to select an
 area fill - the area checkbox is disabled
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2085>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
