[Mapguide-trac] [mapguide-trac] #2085: Maestro - Theme Improvements - Loss of transparency
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 31 07:07:54 PDT 2012
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  Maestro-5.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
Comment(by jng):
 The "Change Base Style" button does nothing ultimately. The base style is
 not used or referenced at all in the code when themes are generated.
 The "template from first rule" approach is much simpler anyways, so I'm
 going to remove this non-working functionality.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2085#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
