[Mapguide-trac] [mapguide-trac] #2087: Fusion editor does not set script source for OpenStreetMap
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 30 23:50:19 PDT 2012
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 In fusion.js, if the ApplicationDefinition contains OSM layers, it expects
 to inject a script link to
 {{{http://www.openstreetmap.org/openlayers/OpenStreetMap.js}}} from the
 {{{OpenStreetMap}}} element in the ApplicationDefinition document.
 Maestro's Fusion editor is not setting this element, meaning the
 OpenLayers.Layer.OSM subtypes are not defined, as the required scripts are
 not loaded.
 Secondly, the Osmarender layer type is no longer available and this
 checkbox option should be removed.
 This problem isn't apparent on MGOS 2.4, as its version of Fusion will
 fallback to OpenLayers.Layer.OSM
 However the fusion in MGOS 2.2 does have this problem as it will cause a
 javascript error trying to instantiate a
 OpenLayers.Layer.OSM.[Mapnik|Osmarender|CycleMap] object
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2087>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
