[Mapguide-trac] [mapguide-trac] #2087: Fusion editor does not set script source for OpenStreetMap
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 30 23:51:42 PDT 2012
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> In fusion.js, if the ApplicationDefinition contains OSM layers, it
> expects to inject a script link to
> {{{http://www.openstreetmap.org/openlayers/OpenStreetMap.js}}} from the
> {{{OpenStreetMap}}} element in the ApplicationDefinition document.
> Maestro's Fusion editor is not setting this element, meaning the
> OpenLayers.Layer.OSM subtypes are not defined, as the required scripts
> are not loaded.
> Secondly, the Osmarender layer type is no longer available and this
> checkbox option should be removed.
> This problem isn't apparent on MGOS 2.4, as its version of Fusion will
> fallback to OpenLayers.Layer.OSM
> However the fusion in MGOS 2.2 does have this problem as it will cause a
> javascript error trying to instantiate a
> OpenLayers.Layer.OSM.[Mapnik|Osmarender|CycleMap] object
New description:
 In fusion.js, if the ApplicationDefinition contains OSM layers, it expects
 {{{OpenStreetMapScript}}} element in the ApplicationDefinition document.
 OpenLayers.Layer.OSM subtypes are not defined, as the required scripts are
 not loaded.
 OpenLayers.Layer.OSM.[Mapnik|Osmarender|CycleMap] object, because the
 required OSM wrapper script is not specified.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2087#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
