[Mapguide-trac] [mapguide-trac] #2297: Performance Report: Gracefully handle maps with broken layers
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jun 23 22:50:12 PDT 2013
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  2.6
  Component:  General  |     Version:  2.4.0
   Severity:  trivial  |    Keywords:
External_id:           |
 If you do a performance report on a map that has one or more layers
 missing, you get a bunch of php errors like the attached screenshot below.
 Broken layers should not derail the performance profiling, though if
 possible such offending layers should be noted.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2297>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
