[Mapguide-trac] [mapguide-trac] #2298: DbXmlException when previewing a layer with composite styles
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jun 23 23:01:16 PDT 2013
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 If you preview a freshly opened layer with composite styles, it will throw
 back a DbXmlException.
 Strangely though, if you then run "Edit as XML", dismiss it and re-run the
 preview it will proceed without issues. So something in the "Edit as XML"
 function is fixing up the XML (ie. stripping off the xmlns:xsi and version
 attributes from any inline SimpleSymbolDefinition elements)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2298>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
