[Mapguide-trac] [mapguide-trac] #2300: XML Validation Error: SymbolDefinition-1.1.0.xsd
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 24 01:53:52 PDT 2013
   Reporter:  andymorf  |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:  Maestro-5.1
  Component:  Maestro   |     Version:  2.5.0
   Severity:  critical  |    Keywords:
External_id:            |
 In Maestro layer editor, pressing the feature-style button the following
 error appears:
 System.Exception: Der Remoteserver hat einen Fehler zurückgegeben: (559)
 MgDbXmlException.:
 An exception occurred in DB XML component.
 Error: XML Indexer:  Parse error in document at line 53, char 114. Parser
 message: attribute 'version' is not declared for element
 'SimpleSymbolDefinition'
 Validating the same layer-document with eclipse-xml editor an equivalent
 error appears:
 cvc-complex-type.3.2.2: Attribute 'version' is not allowed to appear in
 element 'SimpleSymbolDefinition'.
 Changing server/schema/SymbolDefinition-1.1.0.xsd and moving the version-
 attribute definition from element definition to
 complexType definition the problem disappears.
 Is this a problem with SymbolDefinition-1.1.0.xsd?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2300>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
