[Mapguide-trac] [mapguide-trac] #2300: XML Validation Error: SymbolDefinition-1.1.0.xsd
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 24 02:04:34 PDT 2013
   Reporter:  andymorf  |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:  Maestro-5.1
  Component:  Maestro   |     Version:  2.5.0
   Severity:  critical  |    Keywords:
External_id:            |
Comment(by jng):
 If you hit the "Edit as XML" toolbar button, then close the XML editor
 dialog that shows up without making any changes and then do what you were
 doing to trigger that error, does that error still occur?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2300#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
