[Mapguide-trac] [mapguide-trac] #2300: XML Validation Error: SymbolDefinition-1.1.0.xsd
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 24 02:21:45 PDT 2013
   Reporter:  andymorf  |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:  Maestro-5.1
  Component:  Maestro   |     Version:  2.5.0
   Severity:  critical  |    Keywords:
External_id:            |
Comment(by andymorf):
 If opening with "Edit as XML" and pressing "Save" follwing error appears:
 System.Xml.Schema.XmlSchemaValidationException: Der Typ
 'SimpleSymbolDefinition' ist nicht deklariert.
    bei
 System.Xml.Schema.XmlSchemaValidator.SendValidationEvent(XmlSchemaValidationException
 e, XmlSeverityType severity)
 In my layerDef the SimpleSymbolDefinition element is without any
 attributes (as always so far) - but looking at the xsd this should not be
 allowed (use="required" fixed="1.1.0"). Or am I wrong?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2300#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
