[Mapguide-trac] [mapguide-trac] #2303: Map Definition Editor: Model regeneration leaks handles
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 26 20:10:55 PDT 2013
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 If you trigger a model regeneration (ie. Any action that requires a UI
 refresh) in the Map Definition editor it will leak handles. Eventually
 System.Drawing will start throwing System.OutOfMemoryException
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2303>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
