[Mapguide-trac] [mapguide-trac] #2304: OK button in Create Package dialog not correctly enabled
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 26 23:55:03 PDT 2013
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.5.0
   Severity:  trivial  |    Keywords:
External_id:           |
 If you create a package and choose an explicit list of resource ids, the
 OK button will not be enabled if there is not folder path set even though
 we do not want to package via this method.
 The problem is the OK enable button state logic is incorrect
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2304>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
