[Mapguide-trac] [mapguide-trac] #2307: .net/Java web tier test runners
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jun 30 18:26:04 PDT 2013
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  2.6
  Component:  General  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 We currently have a webapi/mapagent test runner. But it is only exercising
 the PHP binding to the MapGuide API.
 To improve our test coverage, the Java and .net bindings should also be
 exercised with the same test suite that drives the PHP one. This obviously
 means porting the PHP test runner over to .net and Java.
 It is not yet determined whether we need to make .net/Java SWIG bindings
 to the SQLiteVM that the PHP test runner uses or we can just access the
 SQLite test suite db using the standard data access APIs provided by .net
 and Java.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2307>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
