[Mapguide-trac] [mapguide-trac] #2381: AJAX viewer legend incorrectly displays layers with both composite and non-composite styles
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 17 18:17:38 PST 2013
composite styles
   Reporter:  jng          |       Owner:  jng
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 If you have a layer with both composite and non-composite styles. The AJAX
 viewer legend will produce swatches for both.
 The correct behaviour is that in such cases, only the swatch for the
 composite style should be produced and the non-composite one ignored.
 The rendering/stylization already disregards non-composite styles if
 composite styles exist. The legend should behave in the same way.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2381>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
