[Mapguide-trac] [mapguide-trac] #2381: AJAX viewer legend incorrectly displays layers with both composite and non-composite styles
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 17 18:18:40 PST 2013
composite styles
   Reporter:  jng          |       Owner:  jng
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by jng:
Old description:
> If you have a layer with both composite and non-composite styles. The
> AJAX viewer legend will produce swatches for both.
> The correct behaviour is that in such cases, only the swatch for the
> composite style should be produced and the non-composite one ignored.
> The rendering/stylization already disregards non-composite styles if
> composite styles exist. The legend should behave in the same way.
New description:
 If you have a layer with both composite and non-composite styles. The AJAX
 This isn't major in the grand scheme of things. Such layers are
 technically invalid and client-side authoring tools should prevent such
 layers from being created.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2381#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
