[Mapguide-trac] [mapguide-trac] #2382: Cannot save a v2.4.0 Layer Definition document via "Edit as XML"
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 17 18:30:58 PST 2013
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.1
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 When you open a v2.4.0 Layer Definition document and then use the "Edit as
 XML" command to edit the raw XML. Maestro will throw this error when
 saving the XML document:
 System.Xml.Schema.XmlSchemaValidationException: Type
 'WatermarkInstanceCollectionType' is not declared.
    at
 System.Xml.Schema.XmlSchemaValidator.SendValidationEvent(XmlSchemaValidationException
 e, XmlSeverityType severity)
    at
 System.Xml.Schema.XmlSchemaValidator.SendValidationEvent(XmlSchemaException
 e)
    at System.Xml.Schema.XmlSchemaValidator.RecompileSchemaSet()
    at System.Xml.Schema.XmlSchemaValidator.Init()
    at System.Xml.Schema.XmlSchemaValidator..ctor(XmlNameTable nameTable,
 XmlSchemaSet schemas, IXmlNamespaceResolver namespaceResolver,
 XmlSchemaValidationFlags validationFlags)
    at System.Xml.XsdValidatingReader.SetupValidator(XmlReaderSettings
 readerSettings, XmlReader reader, XmlSchemaObject partialValidationType)
    at System.Xml.XsdValidatingReader..ctor(XmlReader reader, XmlResolver
 xmlResolver, XmlReaderSettings readerSettings, XmlSchemaObject
    at System.Xml.XmlReaderSettings.AddValidation(XmlReader reader)
    at System.Xml.XmlReaderSettings.CreateReader(Stream input, Uri baseUri,
 String baseUriString, XmlParserContext inputContext)
    at System.Xml.XmlReader.Create(Stream input, XmlReaderSettings
 settings, String baseUri)
    at OSGeo.MapGuide.MaestroAPI.XmlValidator.Validate(Stream xml,
 XmlSchema[] xsds) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
 5.0.x\workspace\OSGeo.MapGuide.MaestroAPI\XmlValidator.cs:line 81
    at
 OSGeo.MapGuide.MaestroAPI.XmlValidator.ValidateResourceXmlContent(String
 xmlContent, String xsdPath, String[]& errors, String[]& warnings) in
 5.0.x\workspace\OSGeo.MapGuide.MaestroAPI\XmlValidator.cs:line 126
    at Maestro.Base.Editor.XmlEditorDialog.ValidateXml(String[]& errors,
 String[]& warnings) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
 5.0.x\workspace\Maestro.Base\Editor\XmlEditorDialog.cs:line 140
    at Maestro.Editors.Generic.XmlEditorCtrl.PerformValidation(Boolean
 silentSuccess, Boolean errorsOnly) in
 5.0.x\workspace\Maestro.Editors\Generic\XmlEditorCtrl.cs:line 246
    at Maestro.Base.Editor.XmlEditorDialog.btnSave_Click(Object sender,
 EventArgs e) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
 5.0.x\workspace\Maestro.Base\Editor\XmlEditorDialog.cs:line 150
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
 button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2382>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
