[Mapguide-trac] [mapguide-trac] #2424: Maestro - LayerDefinition Inefficiencies with Large Schemas
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 10 01:08:03 PDT 2014
   Reporter:  crispinatime  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:
  Component:  General       |     Version:  2.5.0
   Severity:  trivial       |    Keywords:
External_id:                |
Comment(by jng):
 GETIDENTITYPROPERTIES requires a class definition to pluck from.
 GetClassDefinition should be fast if the provider supports GetSchemaNames,
 GetClassNames and friends.
 If the provider doesn't (and I believe this is the case with King Oracle)
 it has to do a full schema description just to find the matching class
 definition to pluck the identity properties from.
 Why it's happening on save is one part because of #2364 (which you also
 submitted) and the other part because of King Oracle's DescribeSchema
 inefficiency.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2424#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
