[Mapguide-trac] [mapguide-trac] #2424: Maestro - LayerDefinition Inefficiencies with Large Schemas
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 10 01:18:01 PDT 2014
   Reporter:  crispinatime  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:
  Component:  General       |     Version:  2.5.0
   Severity:  trivial       |    Keywords:
External_id:                |
Comment(by crispinatime):
 Thanks - it' also seen on SHP which I thought played nicely - but being
 file-based is often pretty quick even if there is brute-force processing.
 (easy to replicate using Windows copy/paste on a set of SHP files within a
 folder to create duplicates / copies and then creating a directory-level
 SHP connection)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2424#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
