[Mapguide-trac] [mapguide-trac] #2432: Subsequent calls to MaestroApi.HttpServerConnection.QueryFeatureSource timeout
MapGuide Open Source trac_mapguide at osgeo.org
Thu Apr 17 03:47:02 PDT 2014
timeout
   Reporter:  johngalambos  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:
  Component:  Maestro       |     Version:  2.5.0
   Severity:  minor         |    Keywords:
External_id:                |
Comment(by jng):
 I tried these two unit tests. A single-threaded one and a multi-threaded
 one. I cannot trigger the timeout exceptions. Do you have a reproducible
 sample?
 [Test]
 public void TestCase2432()
     var conn = CreateTestConnection();
     for (int i = 0; i < 10; i++)
         using (var rdr1 =
 conn.FeatureService.QueryFeatureSource("Library://UnitTests/Data/Parcels.FeatureSource",
 "SHP_Schema:Parcels", "Autogenerated_SDF_ID < 20"))
             while (rdr1.ReadNext()) { }
             rdr1.Close();
 [Test]
     var events = new List<ManualResetEvent>();
         var resetEvent = new ManualResetEvent(false);
         ThreadPool.QueueUserWorkItem((args) =>
             using (var rdr1 =
                 rdr1.Close();
                 resetEvent.Set();
         events.Add(resetEvent);
     WaitHandle.WaitAll(events.ToArray());
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2432#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
