[Mapguide-trac] [mapguide-trac] #2467: MgOutOfRangeException when selecting features whose DateTime entry pre-dates 1970
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 10 22:51:34 PDT 2014
dates 1970
   Reporter:  kshippey   |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  2.6
  Component:  Map Agent  |     Version:  2.5.0
   Severity:  major      |    Keywords:  MgDateTime Selection Error
External_id:             |
Comment(by kshippey):
 I created a small data sample to test with and had to investigate further.
 In migrating customized code to the updated MapGuide 2.6 engine, I have
 been working with both a fusion.js and its compiled fusionSF-compressed.js
 resource.  At this point, one is parsing the date only as date (M-D-Y)
 while the other is attempting to translate to a Date + Timestamp,
 resulting in the above error on the mapagent.fcgi level.
 It appears that the compressed version uses mapagent.fcgi?version=1.0.0,
 while the uncompiled version uses
 mapagent.fcgi?version=2.6.0&requestData=12 as the different parameters.
 It appears the 1.0.0 version returns acceptable Date format (M.D.Y) and
 has no trouble with pre-1970 entries, while the 2.6.0 version attempts to
 parse a timestamp out from the date.
 Attached is DateTest.zip for your investigation.  If off the top of your
 head you have a tip on correcting the mapagent.fcgi version for my
 fusionSF-compressed.js queries (compiled from the same js files that feed
 the non-compiled version 2.6.0 query format), please let me know.  Looks
 like I'll be working that one out tomorrow.
 Thank you,
 Kyel
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2467#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
