[mapguide-users] Failed to test the Web Server Extensions after installation
Dongjin Xing Dongjin.Xing at autodesk.com
Wed Apr 12 17:10:18 EDT 2006
If you get the content of the JSP file, it means that you didn't set up
Apache with Tomcat.
Please refer to this doc to set up your Java application server.
https://mapguide.osgeo.org/docs/InstallMapGuideOpenSourceSamples.pdf
Dongjin
  _____
Sent: Tuesday, April 11, 2006 6:19 AM
Subject: [mapguide-users] Failed to test the Web Server Extensions after
installation
Hello,
I installed the MapGuide server and extenstion v1.0.0 according to the
manual, selecting the following options:
java development
when checking the installation using:
http://localhost/mapguide/mapviewerajax/ajaxviewer.jsp?WEBLAYOUT=Library
://ATest.WebLayout
The browser displays the content of file ajaxviewer.jsp, it should be
"Resource was not found: Library://ATest.WebLayout"
It seems something wrong with Tomcat.
Any help appreciated.
Y.L.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060412/897fa778/attachment.html
More information about the Mapguide-users mailing list
