working with selections ...
Paul Spencer pspencer at dmsolutions.ca
Mon Aug 14 17:46:21 EDT 2006
All,
I've been pulling what little hair I have left out of my head over this!
I would like to create a selection in the map using the PHP API.
I have the following code:
$map = new MgMap();
$map->Open($resourceService, $mapName);
$layerObj = $map->GetLayers()->GetItem($layerName);
$featureResId = new MgResourceIdentifier($layerObj->GetFeatureSourceId
$featureGeometryName = $layerObj->GetFeatureGeometryName();
$class = $layerObj->GetFeatureClassName();
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetFilter($filter);
$wktRW = new MgWktReaderWriter();
$geom = $wktRW->Read($spatialFilter);
$queryOptions->SetSpatialFilter($featureGeometryName, $geom,
MgFeatureSpatialOperations::Inside);
$featureReader = $featureService->SelectFeatures($featureResId,
$class, $queryOptions);
$selection = new MgSelection($map);
$selection->AddFeatures($layerObj, $featureReader, 0);
$selection->Save($resourceService, $mapName);
If I add this ...
echo countFeatures($featureReader);
function countFeatures($featureReader) {
     $i = 0;
     while ($featureReader->ReadNext()) {
         $i++;
     return $i;
it tells me that I have the appropriate number of features in the
feature reader (for the geom and attribute filter chosen) ... in my
test cases, it was over 7000 features so I limited it spatially to
about 200 ... but I don't leave this in because it consumes the
features and nothing gets added to the selection :)
The problem is that after the selection is saved, I don't get
anything highlighted on the map.  I have another PHP script that
retrieves the properties of selected features.  It works if I use the
mapagent to select the features but it doesn't work if I use this php
script ... well, it reports that there is one layer with a selection
but no features on it.
The problem occurs if I use just a basic filter, just a spatial
filter, or both combined.  It also occurs regardless of the number of
features selected from 1 to the full 7000+.
I also tried using my second php script inline to read the selection
info and no joy.  The script that reads the selection info looks like:
$layers = $selection->GetLayers();
$layer = $layers->GetItem(0); //yes there is one layer in the result
$layerClassName = $layer->GetFeatureClassName();
$selectionString = $selection->GenerateFilter($layer, $layerClassName);
$layerFeatureId = $layer->GetFeatureSourceId();
$layerFeatureResource = new MgResourceIdentifier($layerFeatureId);
$queryOptions->SetFilter($selectionString);
($layerFeatureResource, $layerClassName, $queryOptions);
//... etc etc etc
The feature class name is the same in both cases.  The filter seems
appropriate.
I am obviously missing something here but I cannot see what it is.  I
did try saving the $map as well, with no obvious change.  Or is it a
bug?  Oh, I also tried saving the selection as XML and creating a new
selection and initializing it from the XML but that didn't seem to
change anything either.
Cheers
Paul
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
More information about the Mapguide-users mailing list
