[mapguide-users] working with selections ...
Andy Morsell amorsell at spatialgis.com
Mon Aug 14 18:03:22 EDT 2006
Hi Paul,
Are you refreshing the map somehow?  You will not see the selection until
this occurs via an API call back to the server.  In some almost identical
code of mine, I use a JavaScript function to call SetSelectionXML in the
mapFrame.  Or, a call to ZoomToView in the mapFrame also works since it has
to redraw the map and will include the new selection object.
I hope this helps.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Monday, August 14, 2006 2:46 PM
Subject: [mapguide-users] working with selections ...
All,
I've been pulling what little hair I have left out of my head over this!
I would like to create a selection in the map using the PHP API.
I have the following code:
$map = new MgMap();
$map->Open($resourceService, $mapName);
$layerObj = $map->GetLayers()->GetItem($layerName);
$featureResId = new MgResourceIdentifier($layerObj->GetFeatureSourceId
$featureGeometryName = $layerObj->GetFeatureGeometryName();
$class = $layerObj->GetFeatureClassName(); $queryOptions = new
MgFeatureQueryOptions(); $queryOptions->SetFilter($filter);
$wktRW = new MgWktReaderWriter();
$geom = $wktRW->Read($spatialFilter);
$queryOptions->SetSpatialFilter($featureGeometryName, $geom,
MgFeatureSpatialOperations::Inside);
$featureReader = $featureService->SelectFeatures($featureResId,
$class, $queryOptions);
$selection = new MgSelection($map);
$selection->AddFeatures($layerObj, $featureReader, 0);
$selection->Save($resourceService, $mapName);
If I add this ...
echo countFeatures($featureReader);
function countFeatures($featureReader) {
     $i = 0;
     while ($featureReader->ReadNext()) {
         $i++;
     return $i;
it tells me that I have the appropriate number of features in the feature
reader (for the geom and attribute filter chosen) ... in my test cases, it
was over 7000 features so I limited it spatially to about 200 ... but I
don't leave this in because it consumes the features and nothing gets added
to the selection :)
The problem is that after the selection is saved, I don't get anything
highlighted on the map.  I have another PHP script that retrieves the
properties of selected features.  It works if I use the mapagent to select
the features but it doesn't work if I use this php script ... well, it
reports that there is one layer with a selection but no features on it.
The problem occurs if I use just a basic filter, just a spatial filter, or
both combined.  It also occurs regardless of the number of features selected
from 1 to the full 7000+.
I also tried using my second php script inline to read the selection info
and no joy.  The script that reads the selection info looks like:
$layers = $selection->GetLayers();
$layer = $layers->GetItem(0); //yes there is one layer in the result
$layerClassName = $layer->GetFeatureClassName(); $selectionString =
$selection->GenerateFilter($layer, $layerClassName); $layerFeatureId =
$layer->GetFeatureSourceId(); $layerFeatureResource = new
MgResourceIdentifier($layerFeatureId);
$queryOptions->SetFilter($selectionString);
$featureReader = $featureService->SelectFeatures ($layerFeatureResource,
$layerClassName, $queryOptions); //... etc etc etc
The feature class name is the same in both cases.  The filter seems
appropriate.
I am obviously missing something here but I cannot see what it is.  I did
try saving the $map as well, with no obvious change.  Or is it a bug?  Oh, I
also tried saving the selection as XML and creating a new selection and
initializing it from the XML but that didn't seem to change anything either.
Cheers
Paul
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
