[mapguide-users] MapGuide on Fedora Core 5
Marcus Spurkel mspurkel at pacbell.net
Tue Jul 18 15:02:11 EDT 2006
Urk!  Sorry -- lame brain mistake on my part.  Of course you can't pass
the query string on the command line like that.  What I meant to run is
simply:
# /usr/local/mapguideopensource/webserverextensions/bin/mapagent
And I got back a "Segmentation fault".  Does this indicate a problem
with the entire server, or just the mapagent program?
-Marcus
Marcus Spurkel wrote:
> Thanks Traian.
> I've made good progress (I think): Got MapGuide to compile & install
> and I have successfully built FastCGI, which was also a challenge in
> Apache 2.2.  Since I already have Apache installed, I went through the
> build script and applied the settings manually.  I thought I was ready
> to try the mapagent.fcgi test from the "Building and Configuring on
> Linux" PDF, but alas, the server returns a 500 error.  Just for fun, I
> tried running it from a command prompt on the server and got the
> following message:
> ./mapagent?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://
> [1] 18444
> [2] 18445
> -bash: ./mapagent?OPERATION=ENUMERATERESOURCES: No such file or directory
> "No such file or directory"?  Does that mean I don't have something
> configured right?  Is this an obvious error to you?  A little help
> would be greatly appreciated.
> -Marcus
> Traian Stanev wrote:
>> Hi Marcus.
>> The highest gcc we have tried so far is 4.0.2. The "extra
>> qualification" stuff we've already fixed. Only the -pedantic setting
>> in gcc would throw that error before 4.1, and we didn't use that so
>> that's why we didn't catch it.
>> Your solution to the template instantiation is also correct. Removing
>> it shouldn't hurt as far as I know. We'll take care of that too.
>> Please let us know if you have more problems (at least the ones
>> related to MapGuide, hehe).
>> Traian
>>     -----Original Message-----     From: Marcus Spurkel
>> [mailto:mspurkel at pacbell.net]     Sent: Mon 7/17/2006 4:51 PM     To:
>> users at mapguide.osgeo.org     Cc:     Subject: [mapguide-users]
>>     Okay, I may be completely out of my mind here (as well as new to
>> this
>>     project so I probably just don't know any better <g>) but I'm
>> trying to
>>     compile MapGuide on my Fedora Core 5 server with gcc 4.1.1.
>>     Having a devil of a time.  It basically boils down to running make,
>>     waiting for it to bomb out and then looking at and hopefully
>> fixing the
>>     error.
>>     And there are lots of 'em!  Most of the complaints were of the
>> "extra
>>     qualification..." variety so I just deleted the offending
>> qualifier.  I
>>     also ran into the "explicit instantiation of non-template
>> type..." error
>>     in ChannelBand.h.  The best solution I've found so far was to
>> comment
>>     out the line entirely -- it doesn't seem to hurt the
>> compilation.  The
>>     new gcc seems to be a lot less forgiving than the version that
>> MapGuide
>>     is normally compiled with (3.4?)  This may be a fool's quest.
>>     But I _did_ finally get it to compile!
>>     I'm running "make check" right now (so far, so good -- it's an old
>>     machine so it'll take a while) and looking forward to seeing if
>> it will
>>     actually work...
>>     Has anyone else had any experience with MapGuide on a new system?
>>     To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>     For additional commands, e-mail: users-help at mapguide.osgeo.org
>> No virus found in this incoming message.
>> Checked by AVG Free Edition.
>> Version: 7.1.394 / Virus Database: 268.10.1/390 - Release Date:
>> 7/17/2006
More information about the Mapguide-users mailing list
