[mapguide-users] MapGuide Open 1.0.1 and WMS problems
Thomas M. Tuerke thomas.m.tuerke at autodesk.com
Mon Jul 31 13:53:21 EDT 2006
Just an FYI: XML is case sensitive, so unless your example is capitalized for emphasis, I’d recommend trying <Bounds … /> instead.
- Thomas
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Sunday, July 30, 2006 4:54 PM
Subject: [mapguide-users] MapGuide Open 1.0.1 and WMS problems
I am having some problems publishing layers via WMS after upgrading to MapGuide Open 1.0.1.  This problem is similar to those I had recently when I installed MapGuide Enterprise.  When I issue a WMS request to a given layer, I get the following error returned:
<ServiceExceptionReport version="1.1.1">
 <ServiceException code="InternalError">
  The coordinate system conversion failed.
Unsupported coordinate system code.<details>The coordinate system conversion failed.
Exception occurred in method MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 950 in file c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\CoordinateSystem.cpp
</details>
 </ServiceException>
</ServiceExceptionReport>
As I had to do with MapGuide Enterprise, I added <BOUNDS SRS="EPSG:4326" west="-180" south="-90" east="180" north="90" /> to the WMS Bounds parameter for the layer, but I still continue to get this error.
Any help is appreciated.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060731/ea34601b/attachment.html
More information about the Mapguide-users mailing list
