[mapguide-users] MapGuide Open 1.0.1 and WMS problems
Andy Morsell amorsell at spatialgis.com
Mon Jul 31 14:11:02 EDT 2006
Thomas,
I did have it that way for one layer and with proper case on another.  After
making sure they are all consistent, I still get the same error message.
Here is the result of WMS GetCapabillities for one of the layers in
question:
<!--  Published Layer #2   -->
<http://mapguide.spatialgis.com/mapguide/mapagent/mapagent.fcgi?REQUEST=GetC
apabilities&SERVICE=WMS&FORMAT=text/xml#> - <Layer queryable="0"
cascaded="0" noSubsets="0" opaque="0">
  <Name>Samples/Sheboygan/Layers/Hydrography</Name>
  <Title>Hydrography</Title>
  <SRS>EPSG:4326</SRS>
  <LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90" />
  <BoundingBox SRS="EPSG:4326" minx="-180" miny="-90" maxx="180" maxy="90"
  </Layer>
And I am trying to test it via:
http://mapguide.spatialgis.com/mapguide/mapagent/mapagent.fcgi?request=GetMa
p
<http://mapguide.spatialgis.com/mapguide/mapagent/mapagent.fcgi?request=GetM
ap&service=WMS&layers=Samples/Sheboygan/Layers/Hydrography&srs=EPSG:4326&bbo
x=-87.74,43.68,-87.69,43.815&width=500&height=500&format=image/png>
&service=WMS&layers=Samples/Sheboygan/Layers/Hydrography&srs=EPSG:4326&bbox=
Andy
  _____
From: Thomas M. Tuerke [mailto:thomas.m.tuerke at autodesk.com]
Sent: Monday, July 31, 2006 10:53 AM
Subject: RE: [mapguide-users] MapGuide Open 1.0.1 and WMS problems
Just an FYI: XML is case sensitive, so unless your example is capitalized
for emphasis, I'd recommend trying <Bounds . /> instead.
- Thomas
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Sunday, July 30, 2006 4:54 PM
Subject: [mapguide-users] MapGuide Open 1.0.1 and WMS problems
I am having some problems publishing layers via WMS after upgrading to
MapGuide Open 1.0.1.  This problem is similar to those I had recently when I
installed MapGuide Enterprise.  When I issue a WMS request to a given layer,
I get the following error returned:
<ServiceExceptionReport version="1.1.1">
 <ServiceException code="InternalError">
  The coordinate system conversion failed.
Unsupported coordinate system code.<details>The coordinate system conversion
failed.
Exception occurred in method
MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 950 in file
c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\Coordinat
eSystem.cpp
</details>
 </ServiceException>
</ServiceExceptionReport>
As I had to do with MapGuide Enterprise, I added <BOUNDS SRS="EPSG:4326"
west="-180" south="-90" east="180" north="90" /> to the WMS Bounds parameter
for the layer, but I still continue to get this error.
Any help is appreciated.
Andy Morsell, P.E.
Spatial Integrators, Inc.
 <http://www.SpatialGIS.com> http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060731/aa31f23c/attachment.html
More information about the Mapguide-users mailing list
