[mapguide-users] Solve problem MySQL Polygon Selection
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Aug 2 07:48:01 EDT 2007
I have no experience with the PostGIS provider.
I had no delays using OGR for PostGIS data.
Regards Kenneth, GEOGRAF A/S
Dhirendra Kumar skrev:
> Hi Kenneth,
> I make layer using PostGIS provider not OGR Provider. No problems with
> tooltips, it is working fine. only problem with polygon selection taking 4
> second to highlight. OGR Provider can solve this problem ? Yes Kenneth
> before displaying layer or map server use 100% CPU and before tool tips
> displaying server use 10-20% CPU. Any way to overcome this problem ?
> Regards,
> Dhirendra kumar
> Kenneth, GEOGRAF A/S wrote:
>> I recall that there was a problem with selection/info in some version of
>> the OGR.
>> What version of the OGR provider do you use?
>> Does your server use 100% CPU before displaying?
>> Is the problem the same with tooltip's ?
>> Regards, Kenneth, GEOGRAF A/S
>>> Hi Kenneth,
>>> Once again i am asking qustion to you about Postgres/PostGIS, Kenneth I
>>> import table in PostGIS database using shp2pgsql tool. I can create
>>> Layers
>>> from PostGIs Database. But when i select any polygon then polygon
>>> highlight
>>> after 4 second, So can i increase performence of polygon selection ? 300
>>> polygon on current layer. I also provide index but problem is still same.
>>> Any thing wrong in my process ? Please help me.
>>> Regards,
>>> Dhirendra Kumar
>>>> As someone else mentioned, the selection problem is a known bug in the
>>>> MySQL provider.
>>>> You have the following options:
>>>> 1. Wait until someone fixes the problem.
>>>> 2. Download source and fix it yourself (or perhaps pay someone to do it)
>>>> 3. Use another provider
>>>> If you MUST use a "real" database, I can only suggest Oracle (you have
>>>> tried the others).
>>>> Are there any reason that you cannot use SDF files?
>>>>> Hi All,
>>>>> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
>>>>> Postgresql/postGIS and i got result MySQL performance is better in
>>>>> compare
>>>>> of all, but problem in polygon selection. I want to know that, no way
>>>>> to
>>>>> solve this polygon selection problem ? :(
>>>>> PROBLEM:- When i select some polygon then near polygon get highlighted
>>>>> in
>>>>> place of current selection.
>>>>> If anyone have idea or suggestion then please help me. Thankyou in
>>>>> Advance.
>>>>> Regards,
>>>>> Dhirendra Kumar
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070802/f155cf91/attachment.html
