[mapguide-users] Solve problem MySQL Polygon Selection
Dhirendra Kumar dhirendra.mgos at gmail.com
Thu Aug 2 08:57:21 EDT 2007
Hi Kenneth,
Thankyou for your replay once again. If OGR provider have no problem in
selection then i can use OGR Provider in place of PostGIS provider. I am
using MGOS 1.2.0 RC2 and Autodesk MapGuide studio 2007. So, from where i'll
get OGR Provider that work fine with  MGOS 1.2.0 RC2. Thankyou in Advance.
Regards,
Dhirendra Kumar
Kenneth, GEOGRAF A/S wrote:
> I have no experience with the PostGIS provider.
> I had no delays using OGR for PostGIS data.
> Regards Kenneth, GEOGRAF A/S
> Dhirendra Kumar skrev:
>> Hi Kenneth,
>> I make layer using PostGIS provider not OGR Provider. No problems with
>> tooltips, it is working fine. only problem with polygon selection taking
>> 4
>> second to highlight. OGR Provider can solve this problem ? Yes Kenneth
>> before displaying layer or map server use 100% CPU and before tool tips
>> displaying server use 10-20% CPU. Any way to overcome this problem ?
>> Regards,
>> Dhirendra kumar
>>> I recall that there was a problem with selection/info in some version of
>>> the OGR.
>>> What version of the OGR provider do you use?
>>> Does your server use 100% CPU before displaying?
>>> Is the problem the same with tooltip's ?
>>> Regards, Kenneth, GEOGRAF A/S
>>>> Hi Kenneth,
>>>> Once again i am asking qustion to you about Postgres/PostGIS, Kenneth I
>>>> import table in PostGIS database using shp2pgsql tool. I can create
>>>> Layers
>>>> from PostGIs Database. But when i select any polygon then polygon
>>>> highlight
>>>> after 4 second, So can i increase performence of polygon selection ?
>>>> 300
>>>> polygon on current layer. I also provide index but problem is still
>>>> same.
>>>> Any thing wrong in my process ? Please help me.
>>>> Regards,
>>>> Dhirendra Kumar
>>>>> As someone else mentioned, the selection problem is a known bug in the
>>>>> MySQL provider.
>>>>> You have the following options:
>>>>> 1. Wait until someone fixes the problem.
>>>>> 2. Download source and fix it yourself (or perhaps pay someone to do
>>>>> it)
>>>>> 3. Use another provider
>>>>> If you MUST use a "real" database, I can only suggest Oracle (you have
>>>>> tried the others).
>>>>> Are there any reason that you cannot use SDF files?
>>>>>> Hi All,
>>>>>> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
>>>>>> Postgresql/postGIS and i got result MySQL performance is better in
>>>>>> compare
>>>>>> of all, but problem in polygon selection. I want to know that, no way
>>>>>> to
>>>>>> solve this polygon selection problem ? :(
>>>>>> PROBLEM:- When i select some polygon then near polygon get
>>>>>> highlighted
>>>>>> in
>>>>>> place of current selection.
>>>>>> If anyone have idea or suggestion then please help me. Thankyou in
>>>>>> Advance.
>>>>>> Regards,
>>>>>> Dhirendra Kumar
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Solve-problem-MySQL-Polygon-Selection-tf4170008s16610.html#a11963979
