[mapguide-users] Switch Map dynamically
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Aug 3 07:13:32 EDT 2007
I don't know how to re-initialize the ajaxviewer,
but you should be able to overwrite the current Runtime map,
by issuing a MgMap.Create(...) call.
Next step would be to refresh the viewer, but it will not be enough
to do a regular GetMapFrame().Refresh(), as that will not update
the variables with ea. the "screen to map" and "meters pr unit" values.
Regards, Kenneth, GEOGRAF A/S
Manuel Ferreira skrev:
> Hi all,
> I created a few Map Definitions and one Web-Layout definition with
> MapGuide Studio. I want to use one Web-Layout with many Maps and the
> user should switch maps dynamically.
> My question: How to switch a map referenced in the Web-Layout
> dynamically with the API? I know how to create a map and save it in
> the session-repository...
> I use MGO 1.2 (Windows) with the phpviewer.
> Thanks everyone
> Manuel
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
