[mapguide-users] Switch Map dynamically
Jon Rizzo jrizzo at Langan.com
Mon Aug 6 13:46:08 EDT 2007
I do this on my site.  In addition to creating a map in the session
repository, you also need to generate a web layout dynamically & save it to
the session repository.  In order to reference the session's map instead of
the Library's copy, you have to specify the path to the new map in the web
layout BEFORE mapguide is initialized.
Jon
Manuel Ferreira-2 wrote:
> Hi all,
> I created a few Map Definitions and one Web-Layout definition with
> MapGuide Studio. I want to use one Web-Layout with many Maps and the
> user should switch maps dynamically.
> My question: How to switch a map referenced in the Web-Layout
> dynamically with the API? I know how to create a map and save it in the
> session-repository...
> I use MGO 1.2 (Windows) with the phpviewer.
> Thanks everyone
> Manuel
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Switch-Map-dynamically-tf4211857s16610.html#a12020911
