[mapguide-users] MG2007 and PHP as ISAPI on IIS5.1
Rahul unicorn_admirer at yahoo.com
Thu Aug 9 05:49:09 EDT 2007
Hi All,
I am running Windows XP with IIS 5.1. Now I am currently testing with  installed MG Server(on Machine -A)  and MG Web Server Extensions using PHP, a custom IIS config and a typical setup(on Machine -B).When testing the Site Admin use to give the failed logging error using Administrator and admin password and the MapAgent and Server
Extensions throw up this message:
Cannot establish connection.
Cannot establish connection. Exception occurred in method
MgServerConnection.Open at line 95 in file .\Services\ServerConnection.cpp
I installed MG on Windows using the set up guide and step by step method for Php and IIS Configuration and checked all of the criteria including directory structure and the viewer properties etc.Kindly if somebody can suggest me where i am missing the bus i will be really thankfull.
  Cheers
  Max
Luggage? GPS? Comic books?
Check out fitting  gifts for grads at Yahoo! Search.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070809/1c4e80fb/attachment.html
