[mapguide-users] MG2007 and PHP as ISAPI on IIS5.1
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Aug 9 07:28:05 EDT 2007
Not 100% sure how the Site Admin works, but usually you must change the
ip of the server in the file called "webconfig.ini".
It should be present in the topmost webfolder (at least on a standard
installation).
I'm guessing that it still points to 127.0.0.1.
In that file you can also see the ports used for communication.
These ports must be open for the two machines to communicate.
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
> Hi All,
> I am running Windows XP with IIS 5.1. Now I am currently testing with
>  installed MG Server(on Machine -A)  and MG Web Server Extensions
> using PHP, a custom IIS config and a typical setup(on Machine -B).When
> testing the Site Admin use to give the failed logging error using
> Administrator and admin password and the MapAgent and Server
> Extensions throw up this message:
> Cannot establish connection.
> Cannot establish connection. Exception occurred in method
> MgServerConnection.Open at line 95 in file
> .\Services\ServerConnection.cpp
> I installed MG on Windows using the set up guide and step by step
> method for Php and IIS Configuration and checked all of the criteria
> including directory structure and the viewer properties etc.Kindly if
> somebody can suggest me where i am missing the bus i will be really
> thankfull.
> Cheers
> Max
> Luggage? GPS? Comic books?
> Check out fitting gifts for grads
> <http://us.rd.yahoo.com/evt=48249/*http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz>
> at Yahoo! Search.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070809/26f5c934/attachment.html
