[mapguide-users] SQL Server2005 & MapGuide Studio2007
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Aug 20 07:54:27 EDT 2007
It seems unrelated to my problem, so I cannot recommend anything
meaningful.
You can try to look at the various configuration documents in the
server, to see if something looks broken:
http://localhost:8008/mapguide/mapagent/index.html
If you are uncomfortable with Xml, it might be a bit too much work though.
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
> Hi,
>      Thanks for your reply ,i tried to delete the source created using
> FDO-configure SQL server Connection Wizard and then i quit the studio
> and again created the Data resource *sql.FeatureSource* and after that
> when i tried to work with QueryBuilder for theming then again i got
> the same error as before *an Exception Occured in FDO Component.Table
> Does not exits for class'abc:Roads*'.
> Do you think i should delete the data in SQL Server and create a new
> datastore in SQL server and try to connect once again because by just
> deleting the data resource in studio and restarting again unable to
> solve the issue.
> Thks
> Max
> */"Kenneth, GEOGRAF A/S" <ks at geograf.dk>/* wrote:
>     I have experienced an error that looks the same, but using Access
>     databases.
>     It appears that studio caches some information regarding the table
>     layout.
>     When the database changes, it is no longer possible to use the
>     datasource for any purpose.
>     Merely deleting the datasource and recreating it, does not work.
>     Try to delete the datasource.
>     Quit studio.
>     Create the datasource.
>     It should now work correctly.
>     Rahul skrev:
>>     Hi All,
>>                 Currently i am working with SQL Server 2005 and
>>     already created the datastore and geospatial table using the
>>     Map3D 2007 ,I can view the layers and can do online editing
>>     ,updting features etc using the Map3D 2007.
>>     After working fine in Map3D I tried to figure it out with
>>     Autodesk MapGuide Studio 2007 and created a connection using the
>>     MGE 2007 with FDO Provider for SQL Server,I succesfully able to
>>     create the connection and use to get Data Resource and Feature
>>     Class with properties list from the SQL server but when i try to
>>     perfom theming and want to add rule using the condition and
>>     value(Get) ,it use to give error *an Exception Occured in FDO
>>     Component.Table Does not exits for class'abc:Roads*', although
>>     the table is available in the database and i can easily update
>>     and edit using the Map3D 2007.
>>     I also unable to view the layers in the Map or Layout Preview of
>>     the MapGuide Studio,I am bemused and any kind of
>>     reference/support will be of great help.
>>     Cheers
>>     Max !!
>>     Sick sense of humor? Visit Yahoo! TV's Comedy with an Edge
>>     <http://us.rd.yahoo.com/evt=47093/*http://tv.yahoo.com/collections/222>to
>>     see what's on, when.
>>       _______________________________________________  mapguide-users mailing list  mapguide-users at lists.osgeo.org  http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Looking for a deal? Find great prices on flights and hotels
> <http://us.rd.yahoo.com/evt=47094/*http://farechase.yahoo.com/;_ylc=X3oDMTFicDJoNDllBF9TAzk3NDA3NTg5BHBvcwMxMwRzZWMDZ3JvdXBzBHNsawNlbWFpbC1uY20->
> with Yahoo! FareChase.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070820/4a596511/attachment.html
