[mapguide-users] Use MGO 1.2RC2 as a WFS-Server?
Chris Claydon chris.claydon at autodesk.com
Thu Aug 23 11:25:49 EDT 2007
It could be that the Layer preview is not showing the appropriate
extents. Try creating a new map, adding the layer, and setting the
extents to values that match your data.
Chris.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Manuel
Ferreira
Sent: August 23, 2007 3:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Use MGO 1.2RC2 as a WFS-Server?
Hi all!
I'am trying to use MGO 1.2RC2 as a WFS-Server. I published a Sheboygan
data sources via WFS experimentally. Then I created an WFS FDO data
connection and tested the connection successfully. Furthermore I created
a Layer, which references the data source and an FDO-class (from the
data source). Theres no error message, but there aren't any features on
the Layer.
Did anyone use MGP 1.2RC2 as a WFS-Server?
I also tried to use OpenJUMP as a WFS-Client but unfortunately OpenJUMP
doesn't understand the 'DescribeFeatureType' response from MGO.
Thank your for your response
Manuel
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
