[mapguide-users] Use MGO 1.2RC2 as a WFS-Server?
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Aug 24 03:31:20 EDT 2007
I have the same problems as described below.
The reason that it will not open in an arbitrary WFS client, is the use
of datatype "fdo:int32".
If I change "fdo:int32" to "xs:integer", I get one step further.
Next problem is the naming of the schemas, that use "012355:layername"
in the GetCapabilities request and "OGRSchema:layername" in the
GetFeature request.
I am unable to get it working with the "POST" method, but that can be
removed from the template.
After fixing all the above, I still get no data displayed.
I will double check my bounds next week.
Regards, Kenneth, GEOGRAF A/S
Chris Claydon skrev:
> It could be that the Layer preview is not showing the appropriate
> extents. Try creating a new map, adding the layer, and setting the
> extents to values that match your data.
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Manuel
> Ferreira
> Sent: August 23, 2007 3:11 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Use MGO 1.2RC2 as a WFS-Server?
> Hi all!
> I'am trying to use MGO 1.2RC2 as a WFS-Server. I published a Sheboygan
> data sources via WFS experimentally. Then I created an WFS FDO data
> connection and tested the connection successfully. Furthermore I created
> a Layer, which references the data source and an FDO-class (from the
> data source). Theres no error message, but there aren't any features on
> the Layer.
> Did anyone use MGP 1.2RC2 as a WFS-Server?
> I also tried to use OpenJUMP as a WFS-Client but unfortunately OpenJUMP
> doesn't understand the 'DescribeFeatureType' response from MGO.
> Thank your for your response
> Manuel
> mapguide-users mailing list
