[mapguide-users] Show Image On Tooltip
Jackie Ng jackie.ng at aecsystems.com.au
Mon Aug 27 20:56:55 EDT 2007
I do recall that number properties default to floating point, unless you
concat a 0 to the property.
Try replacing
concat("CODE", '.jpg>')
with
concat(concat("CODE", "0"), '.jpg>')
Hope that helps.
- Jackie
Rahul-2 wrote:
>     Hi,
>     I worked on this and its working great with String Property but when i
> select some field with Integer or double property its unable to show the
> image.
>   Problem--------
>   concat(' http://127.0.0.1:8008/mapguide/pics/', ')).
>   CODE is Double and its not working but when i change to PARCEL_CODE
> which is string its working ,Do I have to do some kind of casting or
> conversion to string.
>   Working OK--------
>   Looking forward for some help me inorder to get going with my project .
>   Thanks
>   Max !!
> Jhonn Jairo Vesga Cadena <jjvesga at gmail.com> wrote:
>   WOW, its working now....
> Thanks for the step by step, and thanks to all to take time and answer..
> JJ
>   On 8/2/07, Rich Bauer < rdbauer at gmail.com> wrote:     Just to add to
> that, I was in the process of creating the same step by step, you want the
> " in there too I believe like src=" and .jpg">
> Rich
> Dhirendra Kumar wrote:
> Hi Jhonn Jairo Vesga Cadena,
> I want to know first People property reflect string or integer ? you can
> try
> my steps
> Don't worry follow steps:-
> or .gif and
> click on OK button.
> Regards,
> Dhirendra Kumar
> Jhonn Jairo Vesga Cadena wrote:
> Thanks Dhirendra, I do that, but in full Path, i need put the property
> associated to the query, because the image must be dinamic, i mean im
> showing peolpe,  im tried to write  PHOTO
> where PHOTO is a table property but doesnt work.
> I dont understand what and where concat works. Have some solution for
> this??
> Thanks-
> you have to write  [full  image]>.
> Regards,
> Dhirendra   Kumar
> Hi, i see on www.spokanemaps.com that shows an image when you put your
> mouse
> over the camera. How can i do this??? Some place to give a clue??
> att:
> M󶩬:
> Movistar: 316-524-4147
> Weblog: http://www.jhonnvesga.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> http://www.nabble.com/Show-Image-On-Tooltip-tf4201097s16610.html#a11962949
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> att:
> M󶩬:
> att:
> M󶩬:
>   Pinpoint customers who are looking for what you sell.
> Park yourself in front of a world of choices in alternative vehicles.
> Visit the Yahoo! Auto Green Center.
View this message in context: http://www.nabble.com/Re%3A-Show-Image-On-Tooltip-tf4335412s16610.html#a12360375
