[mapguide-users] Show Image On Tooltip
Rahul unicorn_admirer at yahoo.com
Mon Aug 27 22:12:38 EDT 2007
    Yeh yesterday i able to check that problem and the error was coming due to the default floating points,Anyway thanks a lot for your kind reply and help.
  Cheers
  Max !!
Jackie Ng <jackie.ng at aecsystems.com.au> wrote:
I do recall that number properties default to floating point, unless you
concat a 0 to the property.
Try replacing
concat("CODE", '.jpg>')
with
concat(concat("CODE", "0"), '.jpg>')
Hope that helps.
- Jackie
Rahul-2 wrote:
> Hi,
> I worked on this and its working great with String Property but when i
> select some field with Integer or double property its unable to show the
> image.
> Problem--------
> concat(' http://127.0.0.1:8008/mapguide/pics/', ')).
> CODE is Double and its not working but when i change to PARCEL_CODE
> which is string its working ,Do I have to do some kind of casting or
> conversion to string.
> Working OK--------
> Looking forward for some help me inorder to get going with my project .
> Thanks
> Max !!
> Jhonn Jairo Vesga Cadena wrote:
> WOW, its working now....
> Thanks for the step by step, and thanks to all to take time and answer..
> JJ
> On 8/2/07, Rich Bauer < rdbauer at gmail.com> wrote: Just to add to
> that, I was in the process of creating the same step by step, you want the
> " in there too I believe like src=" and .jpg">
> Rich
> Dhirendra Kumar wrote:
> Hi Jhonn Jairo Vesga Cadena,
> I want to know first People property reflect string or integer ? you can
> try
> my steps
> Don't worry follow steps:-
> or .gif and
> click on OK button.
> Regards,
> Dhirendra Kumar
> Thanks Dhirendra, I do that, but in full Path, i need put the property
> associated to the query, because the image must be dinamic, i mean im
> showing peolpe, im tried to write PHOTO
> where PHOTO is a table property but doesnt work.
> I dont understand what and where concat works. Have some solution for
> this??
> Thanks-
> you have to write [full image]>.
> Regards,
> Dhirendra Kumar
> Hi, i see on www.spokanemaps.com that shows an image when you put your
> mouse
> over the camera. How can i do this??? Some place to give a clue??
> att:
> M󶩬:
> Movistar: 316-524-4147
> Weblog: http://www.jhonnvesga.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> http://www.nabble.com/Show-Image-On-Tooltip-tf4201097s16610.html#a11962949
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> att:
> M󶩬:
> att:
> M󶩬:
> Pinpoint customers who are looking for what you sell.
> Park yourself in front of a world of choices in alternative vehicles.
> Visit the Yahoo! Auto Green Center.
View this message in context: http://www.nabble.com/Re%3A-Show-Image-On-Tooltip-tf4335412s16610.html#a12360375
Boardwalk for $500? In 2007? Ha!
Play Monopoly Here and Now (it's updated for today's economy) at Yahoo! Games.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070827/5c261fdc/attachment.html
