[mapguide-users] Problem with login on Map guide 1.2
uXuf yousuf.hassan at gmail.com
Tue Dec 11 07:03:41 EST 2007
Can you think of something that you might have done exploring it as the
possible cause?
It should work fine if everything was untouched.
uXuf
Klemen Sorcnik wrote:
> Hello,
> i have problems with login on map guide open source 1.2. When i installed
> it worked fine, but next day i want to login again it says Authentication
> failed.
> I havent changed anything (USER: Administrator PWD: admin).
> I had no problems with login in map guide 1.2 RC2. Can anyone  help me?
> Klemen s.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Problem-with-login-on-Map-guide-1.2-tp14248241s16610p14272458.html
