[mapguide-users] Problem with login on Map guide 1.2
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Dec 11 07:26:28 EST 2007
Do you have login trouble with the MapAdmin, WebStudio or MapGuide Studio?
If the problem is with them all, you might consider a reinstall, as that
will clear the password.
Regards, Kenneth, GEOGRAF A/S
uXuf skrev:
> Can you think of something that you might have done exploring it as the
> possible cause?
> It should work fine if everything was untouched.
> uXuf
> Klemen Sorcnik wrote:
>> Hello,
>> i have problems with login on map guide open source 1.2. When i installed
>> it worked fine, but next day i want to login again it says Authentication
>> failed.
>> I havent changed anything (USER: Administrator PWD: admin).
>> I had no problems with login in map guide 1.2 RC2. Can anyone  help me?
>> Klemen s.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/fe2468a1/attachment.html
