[mapguide-users] Cluster configuration support on Linux
Ismael Cams mapguide2007 at gmail.com
Tue Feb 20 04:41:13 EST 2007
Hello all,
is there any chance to have the MapGuide installed in a cluster
configuration on Linux ? Could this be done for example by sharing the
repository between two mapguide servers. I have been experimenting with this
for a while but could not come to a good solution, e.g. information stored
by one server in the repository is not directly accessible to the other
server (restart is needed). In a perfect scenario I would like to use the
two servers in an active, active scenario (loadbalancing) but I would
already be very happy if I could get to a solution for the first problem.
Does anyone has experience with mapguide in a cluster configuration ?
 BTW is it possible to run the mapguide server not under root (but e.g. a
user mapguide) ?
Kind regards,
Ismaël
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070220/ab36556f/attachment.html
